Remove M107 command
                    Hello all, I have minor issue I'm hoping someone can help me with.
Any time I use Cura in Rep Host a M107 (fan off) command is added to my Gcode, first thing after my start Gcode.
I'm using this Gcode on my Makerbot rep2 (after conversion to X3G) the issue is that the fan it turns off is the one cooling the extruder. I have always gone in and manualy removed the M107 before saving the Gcode.
It seems no combination of checking/unchecking the Enable Cooling box (Rep-host Slicer tab) changing min/max fan speed, setting "fan full at height" or "minimum speed" (Cura Print/extrusion tab) will get rid of this command.
Anyone know what setting I can change to stop this command from getting added to my Gcode?
**** end of start.gcode ****)
;Layer count: 150
;LAYER:0
M107
G0 F9000 X-1.844 Y-0.640 Z0.300
G0 X-2.828 Y0.845
;TYPE:SKIRT
G1 F2400 X-3.462 Y1.540 E0.05116
;Layer count: 150
;LAYER:0
M107
G0 X-2.828 Y0.845
;TYPE:SKIRT
The issue may be that there are 3 locations where the slicer can pull an m107 command from. The RH "printer config" start script could have an m107 (mine is m107 s255). The Cura start script has an m107 by default (I removed that line). And Cura "fan max on height" inserts an m107 before Layer 0.
However, "fan max at height" never generates an m106 command on any layer of my resultant gcode. After removing all RH "printer config" gcode scripts, Cura still refuses to generate any m106 commands in the gcode.
How can I get Cura to activate my fan? Can someone please send me a Cura settings file that works for them?
