Z axis wont go any higher than 36.8
Bit of an odd one I will admit.
I and using Repetier Host as a controller for my Anet A8. Repetier seems to think that the max height (z axis) of the printer is approx 36.8. I found this out when i was printing my first tallish print and the z axis stopped going any higher half way through, but the print continued to try and print, but obviously was just spilling over that layer over and over again.
Slightly weird point is that repetier will let me go higher than 36.8 in controls, and this is reflected on the screen of my printer, but the actual z axis will move no more when setting the axis above 36.8.
I thought this might be a hardware issue, so brought the printer up to 36, turned the printer off and on, and then moved the z axis higher - this worked fine. I then homed the z anbd tried to bring to 37 and it again got stuck a 36 - for me this narrows that its an issue with repetier.
I have done all the usual things of checking the max z height is set correctly, tried changing this just in case, tried deleting and re adding the printer - nothing seems to change this magical number of 36.8.
Any help would be greatly appreciated
I can share photos if it helps, and happy to answer any questions the best i can!
G1 Z50
and see if it moves. Ask firmware afterwards with
M114
where it thinks it is. If it did not move or reports 36.8 you have hit the limit in your printer configuration. Most firmwares can save z max in eeprom so check also eeprom settings for z max.
What happens if you send
G1 Z25
G1 Z50
G1 Z75
does it move 3 times same distance? Does M114 increase by 25 every time?
Also check M119 when it stops moving. Maybe you are triggering an endstop so it stops, also I think it ha sno z max endstop.
Doing as followed, the M114 changed by 25 each time, the actual printer moved by 25, then around 10, then nothing on the last command.
Checked M119 at each stage and no change - all set to low
How is it with the display of the A8 - can yo go higher there?
