Setting temperatures does not work for Prusa MK3s
                    Hi.
After the update, which fixed the cameras - thank you, Now if I try to set the hotend or bed temp manually through the UI. it just does nothing.
Any help please?
Richard
Any help please?
Richard
Using preconfigured temperatures in dropdown menu still works (must be predefined in printer settings->extruder). Also of course sending the gcode directly. Just with the know try to change it twice.
Will be fixed in next update.
