Manual Control Z-Min bug
in Bug Reports
Good day,
for my printer i changed the following line in Printer.cpp from the repetier-firmware:
if (destinationSteps[Z_AXIS] < zMinSteps && !isZProbingActive()) Printer::destinationSteps[Z_AXIS] = Printer::zMinSteps;
to
if (destinationSteps[Z_AXIS] < 0 &&
!isZProbingActive()) Printer::destinationSteps[Z_AXIS] = 0;
Software Z min endstop is turned on.
I got a Z Min Pos of 20.04mm in the eeprom.
Then I move Z in negative direction with the manual control buttons.
Here comes the problem:
When going below 0 (like clicking 3 times on the -10 button when at position 20.04), the printer stops at 0, but the Z Min Value in the host software turns red.
So I did some testing (with M111 S24) and found some values where it does and where it doesn't turn red.
With these Z Min Values it does not turn red: 0.04, 10.04, 19.04, 0, 10, 20, 25, 30.5 mm
But with these it does: 20.04, 21.04, 30.04 mm
And with Z min pos = 30.55mm it turns red after several button presses while already being at position 0.
Now I did some testing with destinationSteps[Z_AXIS] while being at Z = 0 and pressing the -10 Z button.
It always returns 0 on the working Z Min Values.
with the non-working values it returns 0, the text goes red, and when i click it again it returns high negative values (ex. -64500)
and with z min pos = 30.55mm it returns -1 for the first 3 presses and then -64501.
Can you help me with this problem?
Best regards,
Florian
to
Best regards,
Florian
the endstop is at ~20mm to 0mm (I modified the homing process so this works) but the printer shall be able to drive up to 0 (he does!)
I use different Z Min Positions for different kinds of extruders, some are a bit lengthier than others.
only problem is that the host loses track of the position somehow when moving manually at some Z Min Positions (but not all) so I have to home again, even though the printer does not drive over the 0mm.
and always check endstops is turned off
thanks for the fast reply!
The printer moves perfectly fine, stops at 0mm, only the host then loses the right position (turns red), but only at some Z Min Positions, not all.
But since I just need to home after that and i dont drive to 0 manually that often, it's not a big deal.
I just thought I'd report it since it seems like a bug to me that it works with some positions and not with others.
