PrusaSlicer 2.2.0 new Filament Overrides on multi extruder
                    Repetier-Host 2.1.6 + PrusaSlicer 2.2.0
'filament_retract_length = nil' should be 'filament_retract_length = nil,2' on slic3r_settings.ini
http://www.mot.net.tw/temp/SNAG-0002.png
Regarding filament_retract_length I see the problem. It did not see it is a filament attribute as it is newer then when I created it. Also saw that the new condition language is not understood to reduce filaments to selection. So some more work for me making it work again.
