Adjusting Auto Bed levelling.
Before I came on board with Repetier, I used Octopi and Klipper and was able to adjust the height of my auto bed levelling within Klipper.
My bed now seems too close to the nozzle and I need to adjust it.
Is there a way I can do that within Repetier? I want to avoid using Marlin in VSCode as it does my head in. I set the printers up many months ago and would rather not have to go back down the VSCode rabbit hole again.
I've also downloaded the latest version of Pronterface, if that helps.
Cheers in advance.
Cheers in advance.
One question is if you have auto leveling in marlin configured? I'm not familiar with that on marlin - only prusa has it for my printers and there i send it without commands. The distance to bed when triggering is configured in a lcd menu entry I can change so it is stored in eeprom. So maybe you also have that value in eeprom and just can change it there?
When I went across to Repetier, I couldn't find any information on using Klipper with Repetier, so I went back to Marlin. (Eugghh!) I had to learn how to use VSCode and it was a VERY STEEP learning curve. I really don't want to ever see a Configuration-H file ever again...
I changed a nozzle and now the nozzle is too close to the bed. So I 'think' I just need to adjust the Z offset again. All the videos I've found show the setup from scratch, not the fine tuning.
