Syncing extrusion flow multiplier in UI
I have a question about syncing the extrusion flow multiplier value in Repetier-server UI.
As I understand then internally Repetier-server is catching it from the gcode (M221) command
or you can set the value manually from UI and server will send M221 command to firmware.
In Klipper firmware, I'm using filament width module and the module is setting the extrusion flow multiplier
internally in Klipper. The Repetier-Server doesn't know that this value was changed.
Is it possible to report the value of the new extrusion flow multiplier to the Repetier-Server
without executing M221 S<percent> command?
which detects when firmware changes flow. Question is does klipper send any message to console when it changes the flow rate? If so what? Then a similar line could be added to klipper.xml firmware description and server would detect the changes from firmware side and show them correctly.
[gcode_macro REPORT_FILAMENT_WIDTH] variable_last_width: 0 gcode: {% set current_width = printer['hall_filament_width_sensor'].Diameter|float|round(2) %} {% if current_width != last_width|float|round(2) %} RESPOND TYPE=command MSG={"FlowMultiply:%d" % (printer['gcode_move'].extrude_factor * 100.0,)} M117 {"Filament:%4.2fmm" % (printer['hall_filament_width_sensor'].Diameter,)} {% endif %} SET_GCODE_VARIABLE MACRO=REPORT_FILAMENT_WIDTH VARIABLE=last_width VALUE={current_width}[delayed_gcode PERIODIC_FILAMENT_WIDTH]
gcode:
UPDATE_DELAYED_GCODE ID=PERIODIC_FILAMENT_WIDTH DURATION=2
and for detecting the flow change in Repetier-Server I'm using the following line.
Great you found a solution to still transfer it, but being quite special so I can not add it be default. But if klipper adds a message by default let me know and I add the response parser.
