Repetier Server on Raspberry Pi4 problems loading.
I have two installations running on my network.
The one that runs on Raspberry Pi4 when entering the dashboard or any other page indicates connection problems.
I have tried to enter from the cell phone, from the desktop pc, from firefox, from chrome, changing the charger, nothing has solved the problem. Before it worked fine.
If I turn off the Wi-Fi network it should establish an ad hoc network but it doesn't.
I don't know what the solution can be.
I don't want to lose the settings.
Other is try login via ssh to see if it is the network dropping or the server crashing. It is a bit fast for wifi connection lost. But also a bit fast for server restarts. So I do not really think it is a network problem.
Did you change the host name of one of the installations? Not sure if identical names can cause it, also you are not using the host names at all.
Anyhow when you are logge din via ssh check the server.log file or check with
ps aux | grep tier
if the pid of the server process changes (then server crashes) or if you see hints on log what is going on.
