Micro- switch initiated pause control for end filament or filament break.
G'day everyone,
I have been experimenting with the pause function in the latest firmware, and would like to add a micro-switch that detects the end or a beak in the filament.
I am not good at programming and would like to know if anyone else has tried to implement this type of control and if so how.
Thanks in advance,
Yowie.
exactly what I am looking for as well.
I want to make sure, the filament is running ( not broken AND not twisted nor knotted in the coil )
I try to achieve this by using a tacho signal converted to a constant level (e.g. High when turning).
But i dont know, how to handle the signal then .
Is it possible to pause a running job and cool down extruder and after a while bed by this external signal ?
Is there a better way then using AutoHotKey?
Thanks in advance for any comment
Ralph Rathmann
(Repetier Host V. 1.0.6 with Vellemann K8200)
I also already made a filament extruder system and incorporated the microswitch in it, so it would be great...
