Autoleveling
I don't see this topic addressed anywhere so I'll ask what I hope is a new question. My I am setting up a homebrew printer roughly based on OrdBot frame and Repetier firmware / Host. The bed is nearly level, but of course never completely so. I am at the point now where, when extruding a "raft" (I think it's called) to begin printing a part, the extruder has a difficult time finding the Z=0 height. When I place the extruder at the proper height and power cycle to set this location as 0 in the firmware / Host software, it of course moves to another X/Y coordinate to begin printing. At this point, the extruder drops down and either scrapes the blue tape or digs into the bed.
(1) I "think" (this is actually a question) I need to know how to level the bed? I've done a "Config / Level Delta / set P1 P2 P3 points", "Calculate Leveling", and M500 Store to EEPROM. This doesn't appear to be sufficient. What else do I need to do in this area?
(2) How do I tell the firmware / Host software where Z=0 is? I don't have a Z probe, this doesn't seem to be a necessity, is it?
Thanks again for your help.
Thank you for the response on the weekend! Sorry to be dense, but I'm still confused.
1. When I set the default to Z max endstop, the "Z home" function tried to take the extruder away from the bed (up as high as possible). (Reversing Z motor direction did not reverse this process.) Surely we're not leveling the bed with respect to running the Z height as far away from the bed as possible?
2. I do have an LCD, but have not found a "set z=0" function in the firmware. Could you elaborate on where this is within the firmware menu structure?
3. I have tried leveling the bed "manually" with a bubble level and assume I'm "close enough" for the firmware to compensate for the remainder. Are you suggesting leveling the bed mechanically by adjusting bed height screws based, for example, on using a sheet of paper between nozzle and bed?
I attempted to use a standard RepRap endstop PCB for a Z endstop and found considerable variance in the microswitch lever. I am now constructing an endstop using a pushbutton switch cut from an old floppy drive. I am not sure yet whether this will provide more accuracy than simply grinding off the lever from a RepRap circuit board. Any experience in this area would be appreciated.
Thanks again for all your help. Your software is inspiring, both capability and creativity!
I understand those requirements. So how does one address the crosstalk which occurs by having and enabling the endstops? I have twisted and separated the endstop cables but the Y bed drift continues. I am replacing the endstop ribbon cables with shielded cable to see if that helps.
Maybe my question is not being stated properly. How can I use the Z=0 Config function, then turn off checking end stops during print, to find out if the crosstalk is causing the print shift?
I replaced the Ymin endstop ribbon cable with a shielded cable and unplugged Ymax and Xmax endstops. I captured the following log. I was watching this print closely. There were Y steps missed which is why I hit Emergency Stop eventually. But there is no way either the Ymin endstop or the Zprobe were triggered. I would have noticed the LEDs on them.
How can I eliminate this error? The printer is unusable with this error! Please help.
20:01:23.037 : N392 G1 X56.832 Y99.3 E524.4404 *116
20:01:23.271 : ok 386
20:01:23.271 : N393 G1 X54.472 Y96.938 E524.9956 *118
20:01:23.646 : ok 387
20:01:23.646 : N394 M105 *9
20:01:25.818 : endstops hit: x_min:L y_min:H z_max:L Z-probe
state:H
20:01:26.115 : ok 388
20:01:26.115 : N395 G1 X50.7 Y93.166 E525.8828 *124
20:01:26.146 : ok 389
20:01:26.146 : N396 G1 X50.7 Y56.833 E531.9249 *118
20:01:26.146 : ok 390
20:01:26.146 : N397 G0 X51.1 Y56.999 F1800 *101
20:01:26.740 : ok 391
20:01:26.740 : N398 G1 X56.999 Y51.1 E533.3123 F900 *38
20:01:29.193 : ok 392
20:01:29.193 : N399 M105 *4
20:01:29.318 : endstops hit: x_min:L y_min:L z_max:L Z-probe
state:H
20:01:29.475 : ok 393
20:01:29.475 : N400 G1 X93 Y51.1 E539.2993 *105
20:01:29.787 : ok 394
20:01:29.787 : N401 G1 X95.244 Y53.342 E539.8268 *113
20:01:29.787 : ok 395
20:01:29.787 : N402 G1 X98.9 Y56.999 E540.6868 *119
20:01:31.365 : Printer reset detected - initalizing
20:01:31.365 : start
@Repetier, Thank you again for your support and continued patience with an obvious newby. As I have said, and will continue to say, receiving support this responsive, detailed, and timely, one-on-one from another country is, in my opinion, astoundingly good.
(1) Your last reply provides very interesting and helpful information. I suspected, from your previous discussions on this forum, that my issue was crosstalk and examining the log verified this problem. I now set out to correct it....
(2) I am using mechanical endstops, standard PCB containing microswitches. Triggering a Ymin endstop by hand, M119 (today) shows:
15:41:38.268 : endstops hit: x_min:L y_min:H z_max:H Z-probe state:H
However, upon examination I find the Signal pin on the endstop goes to GND when triggered. Assuming the standard RAMPS 1.4 and the standard endstop PCB work together to provide this signal to the Arduino and the firmware sees the signal and (normally) behaves properly, is there a recommended way to invert this hard wired logic since you say (above) this is not a reliable method?
(3) As I said, I replaced the Ymin cable with a shielded cable. That is, all 4 wires are physically wrapped with a metallic shield, which is wired to GND on both ends of the cable. While I have attempted to physically separate the endstop wires from the motor wires, they come in close proximity when connecting everything to the RAMPS PCB itself.
(4) I am using a WYZworks Regulated Power Supply 12v 30a 360w for the system, and tried adjust the Y motor pot. I have not found a setting for this pot which makes the bed difficult to move by hand, which suggests to me that I need more current to the Y motor? I have not the equipment to measure the voltage during motor movements, current to the motor during pulses, or capture and observe transient voltage spikes. I also reduced acceleration parameters (to 600) and yesterday's test resulted in only a few dropped Y movements. I consider this progress but still unacceptable as the print was significantly flawed.
Since you so easily and correctly diagnosed this problem, there surely must be a solution because so many people are 3D printing successfully. Again, I appreciate your attention and continue to believe in your product!
I seem to still be confused about homing and Z=0. I do Calibration -> Set Z=0 (although I can't always allow a G1 Z0 to complete since it sometimes drives into the bed when Z=0 is wrong). Next, I do Z home to Zmax endstop. When next I do G1 Z0 (to start a print, for example), the head does not always return to Z=0 (or Z=0.4, etc). I'[ve tried M500 and other ideas, but it feels like I must still be missing something in comprehending the overall process.
Any ideas / further explanation would be appreciated.
