[Linux V1.5.6] Save to Server Bug
When using Repetier-host V1.5.6 on Linux Ubuntu after clicking "Save to server" button to save print to Repetier Server, buttons get disabled, G-code is sent to Server, but after finish, buttons never get enabled again. You can not even close Repetier-host after that, only way is to kill process.
This is not issue with Winodws version.
Probably some Mono framework issue, but maybe you can find some workaround.
Mono JIT compiler version 3.2.8 (Debian 3.2.8+dfsg-4ubuntu4)
