Object Sizing won't unlock
                    So, I want to make my object longer but retain the diameter.  I click unlock in the sizing section.  I change "Y" to 1.5.  "X" and "Z" remain at 1.  But, the new little "MM" boxes you added on the last update all change.  And the diameter of my object changes.  And everything is out of proportion.  So, can you fix this problem or am I required to do something new to unlock the new boxes?  I've already uninstalled and gone back to the older version.  But sometime, I'd like to upgrade.
But the behaviour you describe I can not reproduce. The maximum the sizes change is some rounding differences when scaling changes, but only at irrelevant digits. Do x/z get multiplied by 1.5 in your case?
