Issue with Repetier-Server Monitor 1.3.0
Hi all
My Repetier-Server Monitor shows 2 issues as follows
1) It indicates that a License Reqired and states that you can not monitor free instances of Repetier-Server. my Repetier-Server is a licenced version and fully paid up. How do I fix that
2) On the server list it indicates 4 printers, but on the web site I only see 3, if I do a backup it shows 3 printers, one witth no name or any details how do i delete that
Repetier-Server is running on a windows PC, I had problems with the Linux version detecting the web cams, it would only ever display 2 of 3, and the web cam streaming would crash/fail, the RaspberryPI version would just stop mid print so trying windows version which seems more stable.
Julian
2) Never had that. It might show deactivated printer. Is that on same server? What is the name? Did that exist in the past and was deleted? On every start we query the current list of printers so it should correct on it's own. Also deleting printer when connected is normally detected.
I have only 1 Server, and I have accessed it by IP address 192.168.0.2:3344 and domain name as well, I have also removed the server from Monitor and readded it and still the same.
Are there config files or reg entries that I need to clean out as well, also on the Server-side for the 4 printer issue, is there any config files I can look at to see why it thinks there are 4 and manually delete the duff data. Please note Server is running on a windows platform.
DO you have a full reset tool or a config edit tools that I could use?
C:\Users\<YourLogin>\AppData\Roaming\Repetier-Server-Monitor
Deleting that resets monitor. Just checked it and we do not store if a license is there, so on every connect it must refetch that. Only thing that might be is the chrome cache (from electron) that might have stored an old server response.
Was the server already on pro when you first installed the monitor? If not the cache might be the explanation and you still get the info from the old cached server state.
Before you do that try in register deactivating license and reactivating while monitor is active.
When server is offline monitor should remove the printers from the home view. On restart they should reappear.
