How to install server on a different raspberry pi OS
                    I want to install repetier server on a raspberry pi but I've already flashed it with another OS and setup other applications such as klipper. I can only find an image for repetier server on raspberry pi but I don't want to reflash the whole thing, I just want to install the standalone application. I tried using the normal linux .deb but it couldn't install the arm64 dependancy. Is there a way around this or another version that would work? Thank you.
Which OS do you use?
