Unable to connect ender 3 error com 1 does not exist
                    So needed to purchase a new pc and now unable to get repetier to communicate to ender 3 printer
Is there printer drivers needed
Or can you help me
Or can you help me
You need to install those drivers: https://ftdichip.com/drivers/vcp-drivers/
If you need help for installing the drivers you can check out several tutorials online, like this:
Download, install the drivers and then make sure the printer is detected correctly in Device Manager, you will be good to go after that.
Source: I run several Ender 3 and Ender 3 Max.
