auto-start printing does not work
I'm testing Repetier-Server with Prusa Slicer - after sending the gcode to the 'Print' group the print doesn't start automatically.
Am I doing something wrong?
Best regards
Y
Best regards
Y
However, if you want to directly start the print after slicing, you can use Repetier-Server-Monitor to automaticly upload gcodes, which you put inside a defined folder.
