Repetier 2.2.4 crashes after deleting default configuration
in Linux
On Ubuntu 20.04, RepetierHost cannot boot up anymore after I accidentally deleted the "default" printer. The error is an out-of-bounds exception -- please see the stack trace below. At present, I'm lost on how I can convince RepetierHost to start again. Any ideas?
./Repetier-Host-x86_64-2.2.4_d744af2819685cf1234f10baa5d6c3d1.AppImage
LD_LIBRARY_PATH = /tmp/.mount_RepetiW2mCgs/usr/lib:
MONO_PATH = /tmp/.mount_RepetiW2mCgs/usr/lib
Gtk-Message: 08:45:57.478: Failed to load module "canberra-gtk-module"
Unhandled Exception:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at RepetierHost.view.FormPrinterSettings.comboScripts_SelectedIndexChanged (System.Object sender, System.EventArgs e) [0x0004a] in <63c553364181423faf81fbf20d6b440d>:0
at RepetierHost.view.FormPrinterSettings.formToCon () [0x0001f] in <63c553364181423faf81fbf20d6b440d>:0
at (wrapper remoting-invoke-with-check) RepetierHost.view.FormPrinterSettings.formToCon()
at RepetierHost.view.FormPrinterSettings.LoadDefaultPrinter () [0x00066] in <63c553364181423faf81fbf20d6b440d>:0
at RepetierHost.Main..ctor () [0x002ac] in <63c553364181423faf81fbf20d6b440d>:0
at (wrapper remoting-invoke-with-check) RepetierHost.Main..ctor()
at RepetierHost.Program.Main (System.String[] args) [0x00015] in <63c553364181423faf81fbf20d6b440d>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.IndexOutOfRangeException: Index was outside the bounds of the array.
