ZLift with Firware Retraction bug
                    Hi guys,
I'm think I've found a bug in 0.94 firmware relating to Z Lift on firware retracts.
Retract actually works as I imagine it should, but on undo (G11) the Z move back toward the bed is actually performed during the first X/Y move (so it ramps down toward the table DURING the first X/Y movement instead of dropping down BEFORE the movement begins).
Anyone else using firmware retracts able to confirm?
It is much more noticable when doing simple objects (such as a cube) where the retract ramps a significant distance after a unretract.
I updated just the other day at work, to .92.5 - is .92.6 up yet / if not, when do you expect to put it up?
Thanks for looking into it, really do see benefits to firmware retraction so I appreciate the effort ;-)
