Touch UI - Move/Extrude - Broken UI after update to 1.1.2 from 1.1.0
A have broken UI on the page Move/Extrude in Touch UI in the Repetir-Server version 1.1.2 updated frimn 1.1.0. In the 1.1.0 ot was okay.
Use Chromium browser in the kiosek mode and I was try delete cookies, but not working. Device is Pipo X8 wit resolutio 1280x800 and OS is Debian 9.13 (stretch).
Photo of a broken page: https://photos.app.goo.gl/JESB5oc7hyT9jKbZA
Is this a new bug?
What does it look like for you and what is your screen resolution? Currently no design issue on that page is known. Can you post a screenshot/photo of it (e.g. on imgur.com)
So I guess I'm on a clean state
I use latest Chrome on my Android 11 phone. (OnePlus 7T Pro)
Here are some images of how looks.
https://photos.app.goo.gl/27vvztmHbAd9rSPk9
I get a hover effect showing the current position when trying to pull Z with my finger on the screen in this example, but it doesn't move the handle
Will check z axis on mobile, but these things often make problem on real touch screen. Further down is a move group where you also have buttons to move as alternative. Just checked and it does in deed not move on mobile. Will see if I can find a solution.
Well anyways... this worked fine before the update
Thanks for the fast investigation!
Then I can stop refreshing this tab ;D
