gCode Groups
I have a question regarding gcode groups.
Currently I’m uploading from PrusaSlicer to a printer (I have a few but all behave the same) and I can see my slices gcode in the appropriate group. I can then print the file with no issues at all. However when the print is completed the file has been removed form the selected group, it’s been deleted.
I’m assuming that this is not the correct behaviour of groups as printing that file again is not possible and realising and uploading is the only way.
Have I done something very silly with my setup? Have I the wrong permissions set somewhere? Any help would be gratefully received
Which button are sou using? If you using "Upload and print" it not get stored in the group but rather added into the print queue and started directly.
Does this issue also happen if you upload the gcode manually?
I have my Repeater-Server folder stored on an ext. SATA Hat (sda1) which is mounted at boot as /mnt/diska the Repeater-Server folder is linked back to /var/lib and the original Repeater Folder is renamed. I have the permissions set on /mnt/diska/Repetier-Server... as repetierserver:root.
Every thing is working fine and I although I have had some annoying hardware problems it been very stable and it's been up for some time now.
I'm sure that I have misconfigured something by relocation the Repeater-Server folder but I just can't find it.
That is not storing into a group. To print g-code must be stored in print queue and jobs there get deleted after print is finished. For permanent storage select a group and not the direct print options. I think that option in PrusaSlicer just selects the print queue where groups are ignored.
You can then see the file in the group and print from there in our gui. This will just make a copy for printing and keep the original.
If I understand your answer above upload and print just put the file in a temporary print que but upload put the file in to the gcode group?
Now I understand the difference but I have to ask why? Would it better to have all uploads from PrusaSlicer for example, remain on the Server and for me to manually remove what I no longer need from Repetier-Server? Rather then realising I need to re-print the 'Upload & Print' file only to find I have to reslice etc. and then re-upload it for printing?
Or am I still not understanding the workflow correctly?
