Configuration
Hi All,
is it possible to copy Config.h from AVR To Due vice versa?
i also want to define the UI Pins in userpins.h , iknow to select AVR or ARM here.
and a Question regarding pins :
There are some pins defined by pin number in config.h and others defined in uiconfig.
wouldn´t that be a goal to bring them all to pins.h respectively to userpins.h
it would be easier to configurate the system and to avoid double use of pins.
any thoughts are welcome.
best regards,
RAyWB
best regards,
RAyWB
