one click for all printers
hi all, since i have 7 server and 54 printers is it possible to send a command to all the printers i have in one click?, maybe one click per server?
for example, if i want to set all the bed temperature at 60 for all the printers there is a way to do that in a single click?
thx
thx
However, you can use the API and write a script that sends a command via api to all printers. Just repeat sending command 60 times with correct server APIKEY and printer slug name.
You can then embed the script to a printer @execute command (see advanced printer settings in manual) and make it e.g. sendall so you can run
@execute sendall "M140 S60"
To enable all heated beds.
To reduce typing you can even add a replacement rule so e.g. lines starting with * are sending a command to all.
Regular expression:
should then run replaced g-code
@execute sendall '@1'
Then
*M140 S60
would do the same.
