Tronxy x5sa pro esteps
Hi Guy's,
 Sorry to ask but I've not used my printer for around a year (not had time as I was moving house), and I can't find my paperwork with the info I need (in a box somewhere).
What gcode commands do I need to get the current esteps and to set the new esteps?
Can you also refresh me with the formula to calculate as the Tronxy x5sa is a bit of a bizarre machine?
D.
You might also just try eeprom editor in host or server - that should show values as well and you can change them.
Value is normally steps per full rotation/circumsphere pulley if there is no gear involved. Or just multiply with an error from measurements. circumsphere pulley can be counted from tooth count * tooth distance if you now the belt type and hence tooth distance. Often 2mm.
