BananaPi M3
                    I purchased a Banana Pi M3. It is a RasperryPi "clone" with 8 cores, 2GB RAM and a Sata port, an 8BG emmc as well as an SD Card.
IT seems that it is a strange little bird in that you just don't fire off a RPi image and run it. There are some differences in the board compared to a rpi.
Anyhow, I have it running Armbian and Repetier Server Linux 32 Bit ARM (armhf).
With the Raspberry Pi image you get the touch interface. Is there a way to add it to the install I have on the BananaPi?
So just make that as autostart and you should have your touch screen.
The mini-pc might not be as powerful as the pi, 2 core Celeron versus an 8 core ARM chip. But more RAM and the large 10 inch touch screen is great! Should be a good platform to sit between my two Geeetech A30T's.
