'utf8::not_enough_room' what(): Not enough space
Hey,
I'm new with Repetier. I Installed the RepetierServer-Raspberry-Pi-Immage on a 16GB SD-Card. Whe I put it in my RaspberryPi 3b plus (1GB RAM) it worked until I wanted to add my first printer. After that, the server crashed. Everytime I try to restart it, I run into this error:
Do you have any idea, how to fix it?
terminate called after throwing an instance of 'utf8::not_enough_room'
Aborted
( https://img.robin-w.de/fIKE8/YIyACeji32.png )Do you have any idea, how to fix it?
ssh pi@repetierserver.local with your password (raspberry if you did not chage it) and instll the dev version with
installDev
where the bug is fixed already.
okay, now it doesn't crash anymore. But now I need a license, even if I want to use the free version.
How does this work?
