Upgrading to the Pi Camera Module 3
Hi all,
I am running Repetier Server Pro 1.4.13 Mecury-88 on a Pi 3. It works fine with my Pi Camera Module 2. I wish to update to the Pi Camera Module 3 with auto focus and greater resolution. My installation pre-dates the availability of the Module 3.
When I ssh into the Pi, I find that the Repetier update did not update the underlying Bullseye Linux system so I know that the Module 3 software is not in the system. There are many many updates that may be applied to the Linux system. Perhaps because of lack of disk space.
If I update the Linux system do I run the risk of destabilizing the Repetier host? Does that latest raspberry pi disk image on the Repetier web site support the new Camera Module 3? Is it best to start all over than run sudo apt upgrade? If apt upgrade is the way to go I want to backup all my gcode on the Pi, but I can't find the directory where the files are stored, are they in a database?
Sorry for so many questions, but the Repetier software has worked flawlessly for over a year and I have not delved all that deeply into it.
For timelapse see our video on homepage
https://www.repetier-server.com/documentation/
Smooth Timelapse Videos explains all tricks around timelapse.
https://github.com/ArduCAM/mjpg-streamer/blob/master/mjpg-streamer-experimental/plugins/input_libcamera/README.md
The option isn't even listed there but poking in sources I found this current set of options for libcamer:
but no hdr. Not sure if with video streams hdr is also available. I could think that for still images it uses several snapshots with different exposure to create it.
