stl offsets
in CuraEngine
I'm using command line CuraEngine with my DIY printer through its own interface. I'm encountering an issue where every time I send an STL file to CuraEngine, it changes the origin to the central position of the print bed. However, I've already set the origin in my interface, resulting in my model being moved twice.
Is there an option to avoid changing origin by curaEngine?
machine_center_is_zerois not what I am looking for. The situation is as follows: I am sending an STL file that is already offset (object centered on the print bed with an offset of X=100, Y=100). Additionally, I am providing the print bed width and height to CuraEngine as parameters X=200mm, Y=200mm. The generated G-code is positioned around X=200, Y=200. It seems like CuraEngine is considering two offset parameters - one from the STL file and the second from half of the print bed size. How can I disable or turn off one of these offsets?
