Thermal Shutdown, where are the logs?
I am having thermal issues. Some time into the print, the PID looses its grip and starts oscillating and the printer shuts down.
If I could see what the printer was doing just before it issued the shutdown it would help debug it.
So, where are the logs? I don't have the camera turned on as that doesn't have thermal or command logs.
-OR-
where do I turn on the logs? The command window view is what I want, but that only extends a few hundred lines at best... The shutdown seems random, so I can't sit nearby and watch/listen for it. The last one was 3 hours into a 26hr print, and was about midnight...I wan't even conscience.
-OR-
Apparently the stationary PID is off from reality just enough so that it will allow it to start oscillating after some time...
Help pls...
Help pls...
