Unable to add Kliper on OEM version 1.4.15 with Armbian 23.11.1 Jammy
When the Install button is selected and the Klipper version is selected, a terminal window is opened asking for the password for repetierserver but the terminal window does not accept text input and therefore the password can not be entered.
If a terminal window is opened from Global Settings, it does accept text and the password can be entered.
Is there a way allow the terminal window opened by the Install to accept text?
Or can Klipper be installed into the proper locations for Repetier-Server from the terminal window
On installation it adds a file
/etc/sudoers.d/repetierserver-perms
that allows running klipper install as root due to these lines:
@includedir /etc/sudoers.d
