Default folder or remember folder
Hello again,
wouldn't it be possible somehow that you could specify the folders for certain things per printer or that the software remembers which folder should be used for which function?
So example:
The firmware for a printer is usually always in the same place under the same name (here /.../bla/blub/firmware.hex).
If you want to upload gcode to the GUI, the folder will be where you last worked like the firmware-folder, regardless of what you want to do. That makes no sense...
That's why I think it would be great if you could use per printer to specify the folder and, if necessary, the file name for the firmware and otherwise, for example, the directory for uploading gcode would be remembered, as well as other directories tied to the function
So example:
Yesterday I set up “Pushover” and sent a picture with it. But the image is taken when the printer is in its rest position. Since my CAM hangs on a boom on the Z-axis and the end position after a print is Y-MAX and Z-MAX, I can of course no longer see anything of the printed part.
Would it be possible to provide a previous image here, e.g. directly or shortly before the part is finished? Maybe a trigger as the first position in the final code before the printer moves to its rest position? Or simply the generated thumbnail of the time-lapse (perhaps in original resolution)? This is already possible when it comes to time-lapse, but not (yet) as a trigger for a PushOver image... or is it?
