SD card print
                    Hi, I have a problem with SD card printing.
                            If I start the SD card print directly on my printer, in the marlin firmware menu, it work very well. But, if I start the print via Repetier-host SD card print, it does nothing. My printer received a command because it display 0% on the lcd screen but it's stuck there. The printer doesn't move or heat.
Do you have an idea ?
