Rendering never completes after Upgrade to 1.4.16
in Bug Reports
Ever Since I upgraded to 1.4.16 my uploaded fires don't render.
Everything works fine, the time estimates are OK, it just won't render the previews.
Where do I look to fix this, please??
Win11 22H2 lots of memory and nothing has changed from before the upgrade....
If that is not the case, can you post a g-code that does not work. Maybe there is something in it that makes it fail.
Also see please server.log (in log files) there you see if renderer is started and more info on how it was done.
You should also check in troubleshooting page from main menu. If a process is blocking for some reason following processes will not start. There you can skip that job.
[02.05.2024 13:51:31] : LUA error calling handleAction:...iles (x86)\Repetier-Server\modules\server\lua\render.lua:198: bad argument #-1 to 'loadJSONFile' (string expected, got nil)
what do in need to do? Re-load/reinstall Repetier?
By reset do you mean a reboot or something else??
I have been having issues with windows and other programs forcing restarts on overnight updates even if I have updates paused for 5 weeks. They are sneaking through, lost a 2+ day print to a reboot...
the powerfail restart only works if the print head didn't move, no way to re-home the Z if the model is the in the way. Managed to recover one with really carefull measuments and manually setting the z-height
Reboots of windows is a real problem as it can not be stopped once windows decides it is time. That is why prefer a raspberry pi with Repetier-Server with linux not doing such stuff plus I can shutdown windows even during a print.
would re-installing help?
If I re-start Windows, it -will- re-start Repetier automatically.
Am I better doing a re-install to clean up the Jason files any my setting?
I copied the file and as soon as I started Repetier, it started rebuilding, unsuccessfully. Everything works, just no previews...
