Connection Lost
                    I'm facing two issues in V1.4.18 and 1.5.0 (Updated by Install Dev), Firstly, the Filament detection sensor is not working, and secondly, connection lost issues are coming frequently after starting the print command.
https://www.repetier-server.com/knowledgebase/connection-problems-with-printer/
Regarding filament sensor - do you mean it does not work in formware or detection of state? In latter case it really depends on your firmware and configuration if we can detect it. We need a signal/message from the printer so we can pause and switch to change filament. Typical messages are normally included. In marlin you might need to activate signaling the host if that command is already supported in your version, see
https://marlinfw.org/docs/gcode/M412.html
