3mf , saved compilation, file corrupted by scaling faktor decimals, comma instead of decimal point
                    Due to cooldown shrinkage I often use a scaling factor of [1.014 , 1.014 , 1] with my cheap and weird PET-filament.
Printing is fine with Slic3erPE , but I can't save a compilation and reload it later on.
Found the bug and a manual workarround: Inside 3mf (basically a zip-file), 3dmodel.model, last line , mismatch of decimal point
is: <build><item objectid="1" transform="1,014 0 0 0 1,014 0 0 0 1 280 320 0" /></build></model>
should be: <build><item objectid="1" transform="1.014 0 0 0 1.014 0 0 0 1 280 320 0" /></build></model>
After manual correction, this 3mf can be reloaded easily.
Scaling included in an exported STL is not an option; changing the filament-material, outsourcing to a 3d-print-service or CNC-milling will misslead for shure.
