Is there a way to set the brim to only be on the outside of the part?
                    I am using version 2.3.2 using the Cura engine that came with it. Is there a way to set the brim to only print on the outside of a shape? I'm having some issues with it trying to print the brim in a small space and it detaching.
I see references to a "Brim only on outside" setting on a few sites, but I don't see it in Repetier. Is that an older setting that is no longer used, or is there a way to get to it that I am not seeing?
