Printing hangs in 1.5.0
Hi there,
I tried the DEV version 1.5.0 in anticipation of my Bambulab x1c. I have two other klipper printers configured, running fine in 1.14.8. After upgrading to 1.5.0 I can still move the axis, calibrate, etc, but when I start a print, the printer hangs, repetier server hangs and can only be revived with a sudo reboot from console.
especially output from
this shows where server is completely hanging. Unfortunately without lines but normally I find it knowing at least the function where it happens.
