layerChanged event has wrong values
I run in a minor bug today.
I run a repetier server with version 1.4.16 on it and was logging some events using the websockets.
The layerChanged event always showed the wrong value for layer:
Note: the maxLayer of the printed object is 15, and the layer value never changed during the whole print.
I then updated to 1.4.18 to check if this has been fixed - sadly not, but its different.
The value of layer is now correct, but unfortunately the maxLayer value is now always the same as the layer value:
Feel free to delete the discussion, if this has been reported before
[Prusa_Mk3s_with_Enclosure]: OnLayerChange - {"data":{"layer":15,"maxLayer":15},"event":"layerChanged","printer":"Prusa_Mk3s_with_Enclosure"}
- [Prusa_Mk3s_with_Enclosure]: OnLayerChange - {"data":{"layer":1,"maxLayer":1},"event":"layerChanged","printer":"Prusa_Mk3s_with_Enclosure"}
- [Prusa_Mk3s_with_Enclosure]: OnLayerChange - {"data":{"layer":2,"maxLayer":2},"event":"layerChanged","printer":"Prusa_Mk3s_with_Enclosure"}
- [Prusa_Mk3s_with_Enclosure]: OnLayerChange - {"data":{"layer":3,"maxLayer":3},"event":"layerChanged","printer":"Prusa_Mk3s_with_Enclosure"}
Same gcode, maxLayer should therefore be 15.
Best regards | Viele Grüße
