Error: Wrong checksum
I just got my trevo flash 3d printer, its secondhand but is supposed to work fine. I'm extremely confused as to why this is happening, i've been trying to print something and continue to get these logs non stop
23:07:41.318 : Error:No Line Number with checksum, Last Line: 14
23:08:20.290 : Error:checksum mismatch, Last Line: 14
23:08:20.292 : Resend: 15
but it repeats over and over again
  • Please activate ping-pong mode in serial settings first. This happens on communication errors. Either you are flooding with to much data (input buffer too big which ping pong prevents as it only sends one line and waits for ok) or your baudrate is wrong cauing many errors. Especially 230400 instead of 250000 can cause this easily.
  • I've trouble shooted with that already with no luck :(
  • You can try different usb cable or different usb port. Sometimes it helps. When settings are theoretically correct it is normally interference with something adding noise to communication. Does it get some lines done just many checksum errors or is it not working at all? The error messages come from printer so that direction seems to work.
  • It doesn't start printing at all
  • Do I need to configure the printer or somethint with an outside source or will this do that for me?
  • null
    I tried this and it also didn't work unfortunately
    I also tried doing it through the server instead but that just kept popping up with error messages. It would say print time 4s and then just error message
  • Did you select Marlin as firmware? I think that is what it is running. If it would use binary format for repetier-firmware it would not understand anything. If nothing works you need to print via sd card. Normally not needed but all typical reasons are now tested. Only thing that might show a bit more is a full log where it transitions from working to not working with all data send and received. Maybe it shows something not thought of.
  • edited April 2025
    It sounds like your Trevo Flash 3D printer is having communication issues between the printer and your computer or controller. The errors you're seeing:
    Error: No Line Number with checksum, Last Line: 14 Error: checksum mismatch, Last Line: 14 Resend: 15
    ...usually point to corrupted or incomplete serial communication. Here are a few things to try:
    1. Check USB Cable – Replace the USB cable with a high-quality, shielded one. Cheap or damaged cables are a common culprit.
    2. Try a Different USB Port – Preferably one directly on your motherboard if you're on a desktop.
    3. Lower Baud Rate – In your slicer or host software (like Pronterface or OctoPrint), try lowering the baud rate (e.g., from 250000 to 115200).
    4. Update/Reinstall Drivers – Make sure your USB-to-serial drivers (like CH340 or FTDI) are correctly installed.
    5. Try a Different Host Software – Sometimes switching from one (e.g., Cura) to another (e.g., Pronterface or Repetier-Host) can resolve odd comms issues.
    6. SD Card Print – Try slicing your file and printing directly from an SD card to bypass the computer entirely and see if the issue persists.
    If it works from SD but not over USB, the issue is likely with the cable or port. Let us know how it goes!
