Printing with delta printer isn't working, very jittery.
Hi everyone,
I've been building a delta printer from scratch using the Mega/RAMPS 1.4 platform. I can control and home the printer without any issues using the manual controls in Repetier-Host—it moves accurately and smoothly across all three axes.
However, I run into a problem when I try to print something.
I upload an .stl file to Repetier-Host, slice it, and everything appears normal—the print path is displayed correctly, and the estimated print time looks reasonable. Since I haven't built the extruder yet, I select 'Dry Print' mode to simulate the movement. When I start the print, the printer homes itself and moves to the starting position, but then, depending on the slicer I used, it either stops completely or moves in small, jittery steps. Either way, it doesn’t move as it should.
The strangest part is that the UI shows the print progressing extremely fast, as if it’s completing a one-hour print in under a minute, even though the platform is barely moving.
I’m not sure if this is a firmware issue or if I’ve misconfigured something in Repetier-Host. Any help would be greatly appreciated!
Thanks in advance!
Also disable easy mode so you see log and check if there are communication errors. When buffer size is set too high you get man errors cauing start/stop often.
One thing that I've noticed is that after I've sliced the model, the print preview, which shows me the path that the printer is going to take looks extremely jittery, random, and all over the place, nothing like what it should look like (I am trying to print a simple cube). This is the case when I try using all 3 of the integrated slicers within Repetier Host. If I try using PrusaSlicer outside of Repetier, it provides me with a path very systematic and normal looking. Maybe it is also important to note that I am controlling the printer by connecting my laptop directly to the Arduino, instead of using an sd card or whatnot. Thanks
https://drive.google.com/drive/folders/116e3DC8XDkWFLuPFeSToE5rJxnK1ViLu?q=sharedwith:public%20parent:116e3DC8XDkWFLuPFeSToE5rJxnK1ViLu
Once again many thanks.
