SD card recognized but no files
edited September 2025 in Repetier-Firmware
When I insert sdcard it is seen but I cannot see any files.
Files on sd card or *.gcode
What can be the cause?
thanks
  • First check if it it is vfat formatted and not too big. Also try .g extension. Also only sd cards with SPI support are supported, firmware has no parallel reader support.
  • So fat32 does not work?
    Ill try thanks.
  • Fat32 should also work.
  • Hi, found the issue.
    There is an extension cable for the SD card, that was making bad contact.
    Fixed it and now it shows all g-code file.
