Compilation problems with Thermocouples- MAX31855
                    Currently, I test the new Ultratronics V1.0 (Due based) from Reprapworld.
The board is working fine with a Marlin Kimbra : 3 Axis, 3 Extruder with Thermocouples (Max31855), Heated Bed, Fan... The machine already print several parts, everything works perfectly.
I would like to switch to Repetier 0.92.8 because some commands are missing or less good in Marlin.
I modified the pins.h following the pins.h of Marlin and try to setup Extruders for reading Thermocouple.
When I set : #define EXT0_TEMPSENSOR_TYPE 102 (the MAX31855)
I get that compilation error messages :
In file included from sketch\Repetier.h:476:0,
from sketch\Extruder.cpp:22:
sketch\Extruder.cpp: In static member function 'static void Extruder::initExtruder()':
HAL.h:165: error: 'DIOSS_PORT' was not declared in this scope
#define _WRITE(port, v) do { if (v) {DIO ## port ## _PORT -> PIO_SODR = DIO ## port ## _PIN; } else {DIO ## port ## _PORT->PIO_CODR = DIO ## port ## _PIN; }; } while (0)
sketch\HAL.h:166:22: note: in expansion of macro '_WRITE'
#define WRITE(pin,v) _WRITE(pin,v)
sketch\Extruder.cpp:538:13: note: in expansion of macro 'WRITE'
WRITE(SS, HIGH);
HAL.h:165: error: 'DIOSS_PIN' was not declared in this scope
WRITE(SS, HIGH);
WRITE(SS, HIGH);
WRITE(SS, HIGH);
exit status 1
To be frank, as there are different #define variables in Marlin and Repetier, I am not sure the pin mapping is perfectly correct.
The guy of Reprapworld who developed the Ultratronics knows well Marlin but is not familiar with Repetier and have some difficulties to help me.
Do you have any ideas on which way I could search ?
Current Configuration :
-Arduino 1.6.7 on Windows 7
-Ultratronics V1.0
-Delta, 3 Axis, 3 Extruders with Thermocouples, 1 Heated Bed with Thermistor, No screen, No SD, No EEPROM
WRITE(SS, HIGH);
WRITE(SS, HIGH);
WRITE(SS, HIGH);
WRITE(SS, HIGH);
exit status 1
-Ultratronics V1.0
