Z-Probing working except right side (P2) is about 1mm too high compared to P1 and P3
                    Hello,
I finally got the X-Probing to work and it's fairly accurate now on the left side to middle of the print area. But when it does to the right side where P2 measure the nozzle raises about .5 to 1.0 mm to high. Otherwise the nozzle passes the paper test close to P1 and P3.
This is my setup.
8mm induction sensor
Glass plate (400x400) with steel washers taped to the underside of the glass, they are flat and pressing evenly. First thing I checked.
bed is level within 1mm
I use the 3 point measuring method P1, P2, P3
I have bed coating set to 0 since I'm compensating for the thickness of the glass.
Any ideas why the right hand side it a little off? I can't think of anything else to check?
This is my setup.
Yes... I'm using G32 S2 and distortion correction is set to 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
//#define Z_PROBE_PIN ORIG_Z_MAX_PIN
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 50
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 2
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 2.0 ///2.5 //new
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 51
#define Z_PROBE_Y1 0
#define Z_PROBE_X2 386
#define Z_PROBE_Y2 0
#define Z_PROBE_X3 51
#define Z_PROBE_Y3 320
#define BED_LEVELING_METHOD 0
#define BED_LEVELING_REPETITIONS 1
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
14:18:39.085 : N25 G28 *4
14:18:40.819 : X:0.00 Y:0.00 Z:309.700 E:0.0000
14:19:10.476 : N36 G32 S2 *76
14:20:31.772 : Z-probe:26.88 X:51.00 Y:0.00
14:20:46.241 : Z-probe:26.98 X:320.00 Y:0.00
14:21:01.538 : Z-probe:26.38 X:51.00 Y:320.00
14:21:07.678 : plane: a = 0.0004 b = -0.0016 c = 26.8640
14:21:07.678 : Transformation matrix: 1.000000 0.000001 -0.000362 0.000000 0.999999 0.001578 0.000362 -0.001578 0.999999
14:21:07.678 : CurrentZ:26.36 atZ:12.10
14:21:07.678 : Z after rotation:11.61
14:21:07.694 : Printer height:324.45
14:21:08.178 : Info:Autoleveling enabled
14:21:08.960 : X:50.99 Y:320.04 Z:25.871 E:0.0000
14:21:28.750 : N48 G1 X51 Y0 *1
14:21:39.500 : N53 G30 *12
14:21:46.178 : Z-probe:12.64 X:51.24 Y:-1.05
14:22:05.433 : N62 G1 X320 Y0 *60
14:23:20.477 : N88 G30 *10
14:23:23.727 : Z-probe:12.63 X:320.24 Y:-1.02
14:23:47.791 : N98 G1 X51 Y320 *13
14:26:04.734 : N144 G30 *59
14:26:07.984 : Z-probe:12.13 X:51.24 Y:318.98
Thanks all.
And yes, I confirm that there are issues with plane calculation, and right side has a bit wrong value for me, too.
