New to Repetier setting up RADDS+DUE+RAPS128
I am setting up a Delta with RADDS1.5+DUE+RAPS128 with Hall-E end stops. FSRs with JohnSL FSR Endstop Board for bed leveling, 24v E3d v6 effecter. Kysan 1124187 .9 steppers , Kysan 1040222 Gear Ratio 5.18:1 for exstruder. 24v power supply, 12v heat bed, thermistor don't rember the type.
Looking for some sample configuration.h files. And some advice on most practical delta set ups using repeatier Firmware. Have not used Repetier or Merlin or RepRapferware. But have used Machinekit on a previous Delta.
https://www.dropbox.com/sh/lq7lcifbu1ytu5t/AAAUoGjSx0SXED9e2aQa7PPoa?dl=0
deltaSegmentsPerSecondPrint: 300,
deltaSegmentsPerSecondTravel: 300,
deltaSegmentsPerLine: 80
stepperHighDelay: 1
directionDelay: 0
stepDoublerFrequency: 80000
doubleStepDelay: 0
moveCacheSize: 24
Do you think these differences can make such a big difference? My axis as very jerky movement.
https://www.dropbox.com/s/73nvpcsr7z82qca/Configuration.h?dl=0
