v092.9 Printing Issue
I have a kossel 3d printer. I have uptaded the firmware to v092.9 but I have problems with it. Even if I spent too much time to re - calibrate the printer, the printer started to print in unintended shapes. What I mean is that, for example it started to print circular shapes in ellipsoid shapes. Also, even if the extruder head moves nicely when it is manually controlled, when it begins to print extruder head goes strange directions and z level is going up.
Dear Repetier, have you tried or tested v092.9 on any delta type printer?
