Safety switch for Laser
is it possible to use one I/O pin and of coarse to check in a loop to block operation when firmware is set to Laser mode?
I think everybody should use a cover around laserbeam for his own safety and let machine only operate when
cover is closed.
touching a rotating mill flute can cut fingers and can be mostly repaired by doctor but looking even to a reflection of a laserbeam <20mW on a metal surface can damage your eyes irreversible.
So a use of a safety lock is a must , we should not build dangerous machines !
best regards,
RAyWB
cover is closed.
best regards,
RAyWB
What do you think about this :
just doesn´t execute G-Code when Feature is selected , works fine for me :
in Repetier.h (i put it to line 249)
#if FEATURE_SAFETY_DOOR && SAFETY_PIN < 0
#error You need to define SAFETY_PIN to use Safety Door!
#endif
in Configuration.h (i put it after Case Light)
#define FEATURE_SAFETY_DOOR true
#define SAFETY_PIN 69
#define SAFETY_PIN_PULLUP 1
in Printer.cpp (i put it after Z-Probe)
#if FEATURE_SAFETY_DOOR && SAFETY_PIN>-1
SET_INPUT(SAFETY_PIN);
#if SAFETY_PIN_PULLUP
PULLUP(SAFETY_PIN, HIGH);
#endif
#endif // FEATURE_SAFETY_DOOR
in Commands.cpp
add to processGcode before switch(com->G)
if (Printer::mode == PRINTER_MODE_LASER)
if (FEATURE_SAFETY_DOOR)
if(READ(SAFETY_PIN))
Com::printWarningFLN(PSTR("SAFETY DOOR OPEN"));
UI_STATUS("SAFETY DOOR OPEN");
return;
else
Com::printWarningFLN(PSTR("USE SAFETY GOOGLES"));
UI_STATUS("USE SAFETY GOOGLES");
of coarse it doesn´t stop host sending , but it doesnt execute g-codes also from SD without affecting anything else in Firmware .
only thing i don´t understand , if i set FEATURE_SAFETY_DOOR false and SAFETY_PIN to -1 i get compiler error because of the READ(SAFETY_PIN),couldn´t find out why ...
best regards,
RAyWB
#ifdef DEBUG_PRINT
debugWaitLoop = 1;
#endif
// if feature active check pin and set blocking mode here maybe also disable laser driver here
if(!Printer::isBlockingReceive()) {......
i also thought about doing it in checkForPeriodicalActions via eventtimer100ms
hard blocking laser for my point of view is only possible by hardware via real and-gate
(sorry for that but I´m Hardware Guy educated in middle 80´s)
One question to your Laser setup what kind of Laser do you use and what´s your experience with that stuff?
I´ played with the Osram 1,6W blue Laser Diode and unfortunatley killed it by disadjusting Optics...
Beam killed Laser itself...
Ordered a 3W complete module in US now...it´s on the way
but is there a possibility to stop actions in buffer?
when i use this , it seems program doesn´t reach the code from my 1st proposal.
can you please tell me about the order commands are processed?
CODE:
#include "Repetier.h"
const int8_t sensitive_pins[] PROGMEM = SENSITIVE_PINS; // Sensitive pin list for M42
int Commands::lowestRAMValue = MAX_RAM;
int Commands::lowestRAMValueSend = MAX_RAM;
bool BLOCK = false;
uint8_t laser_intens = LaserDriver::intensity;
void Commands::commandLoop() {
while(true) {
#ifdef DEBUG_PRINT
debugWaitLoop = 1;
#endif
#if (FEATURE_SAFETY_DOOR && SAFETY_PIN > -1)
if ((Printer::mode == PRINTER_MODE_LASER)&&(READ(SAFETY_PIN)))
LaserDriver::changeIntensity(0);// works immediate!! tested on a single move g1
//LaserDriver::laserOn = false;// waits until end of move
Com::printWarningFLN(PSTR("Host blocked"));
UI_STATUS("Host blocked");
Printer::setBlockingReceive(true);
BLOCK=true;// be shure communication is blocked from here
if(BLOCK && (!READ(SAFETY_PIN)) )//set blocking back when door closed
Printer::setBlockingReceive(false);
LaserDriver::changeIntensity(laser_intens);//restore laser intensity
//LaserDriver::laserOn = true;
UI_CLEAR_STATUS;
BLOCK=false;
#endif
... and so on....
when i just have 1 slow g1 move in buffer it switches off laser immediate.
when buffer is 32 it flashes until buffer is empty
that´s what i figured out , dont care i use just simple led for tests
I´m not really shure how the laser driver works, so may be youll find the time to explain the flow.
when i finished i´ll send a pull request, i also implemented Z-Probe to quick menu just take a look at that stuff.
best regards
As I´m actually working on a "Finger Safe" M6 implementation and dont want to use one
more pin for acknowledge that tool change is done, what means that fingers are away from spindle..
M6 GCode description says it´s waiting for Cycle Start to be pressed, but there´s nothing said about
extra button called "Cycle Start".
my spindle is 1200 W,flutes up to 20mm dia so it´s an important feature .
may be i can go via uiwizard , or how can i check for any key pressed without using ui?
I´m thinking about a flag but i don´t know how to generate/set/reset it.
maybe you can point me a way
we have the possibility to start z-probe cycle by triggering probe, why not use that pin to trigger cycle start also?
so after toolchange we should also measure tool length, so it might be nice to trigger the same way.
whats your meaning about that?
What i just want to do is meet standards when implementing GCodes.For shure there are some variations.
Description Source for example http://www.tormach.com/machine_codes_gcodes.html
History for my intention:
Up to now i made Prototype PCB on a homemade machine based on a crosstable with dovetail guides which were
extremly slow but also precise.
Machine is conrolled by GRBL on Arduino Nano Plagiate and i developed a Printer unit based on Nano with teacup Firmware
switching over just by multiplexing Controllers to the xyz drive on the intents of use.
Toolhead just changeable within 5 minutes.
worked fine , but as the dovetail guides were made from aluminum they are ready for recycling now... a few hundred operating hours later. Anyway, i learned a lot about mechanics :-)
My machine now is bigger, faster and "rocksolid" , has nothing to do with the "modified Printers" where milling is in the best
case a kind of engraving.
As it´s built for universal purpose I also want the Firmware match the requirements so that´s why i try to bring the ideas in.
(Maybe including some stupid questions ;-) )
I "learnt" some programming in Turbo Pascal 4/5(long long time ago) , did not continue for many years so knowledge got lost.
So on this way I´m happy to have the chance of learning by doing useful things.
but back to beginning,
if working with z-probe to measure tool lenght or z-height etc. it´s important to have a moveable probe.
I just use a piece of printed board with known height (offset). Tool is connected to ground , Z-Input via Optocoupler
to Z-Probe input. cheap solution, works precise and by using opto also safe (for controller) and without crosstalk.
that´s also my z-probe for printing, just connect hotend to gnd.
I agree with a modified G30 , i´m also happy with a modified G29 which i already have because of heating stuff.
i use it after nozzle change for example.
I think also of implementing M7 to 9 for additional hardware like vacuum cleaner for example.
Lots of possibilities and of coarse lots of buttons... thats why i was so fixed on the I2C routines.
but step by step.
Think i´ll get the M6 done this weekend and send a pull request against Development branch including
the Safety Switch and Z-Probe start via Quickmenu.
I´ll include the modified G29 also in a seperate file maybe you can take a look on it , i have no delta printer for testing.
was just an example..(i just use it from a button)
the M6 code is just " a break " in gcode, that shows what tool has to be used next needs an acknowledge by button when finished.
so it´s not too hard to implement,just : stop executing code-->> show message-->> wait for ack-->> continue
so description from linux cnc :
LinuxCNC includes a userspace HAL component called hal_manualtoolchange,
which shows a window prompt telling you what tool is expected when a
M6 command is issued. After the OK button is pressed, execution of
the program will continue.
The hal_manualtoolchange component includes a hal pin for a button that
can be connected to a physical button to complete the tool change and
remove the window prompt (hal_manualtoolchange.change_button).
measuring tool lenght for example in GRBL used is G38.2
so the flow in GCode for a tool change is not a single M6 , it looks as follows:
(snippet of Drill file i used on GRBL generated via
(.../EAGLE-7.1.0/ulp/pcb-gcode.ulp)
(Copyright 2005 - 2012 by John Johnson)
...executed code
G01 Z-2.1000 F200.00
G00 Z2.0000
M05 //spindle stopped here
G00 Z50.0000 //move Z up
G00 X0.0000 Y0.0000 // go to defined xy position
M06 T02 ; 0.8128 // M6 just says "change the tool " and waits for ack
M03 // continue
G04 P0.500000
G00 X-20.3200 Y29.2100
So that works without tool length measurement because of my drill bits all have same Z-length adjusted by ring.
Spindle control is done outside of M6 BUT:
some people generate their gcode by hand(me also sometimes) ,a forgotten "M5" will keep spindle running and i think its not bad to switch off (even when its already off) and block the spindle before acknowledge by button for safety reasons.
there will be no change for operation.
Example for G-code tool length measurement
G00 z50.2
G00 X0.0000 Y0.0000
M00 //break
G00 Z50
G38.2 z-50 f100 // move z down until triggered
G92 Z1.75 // set Z-Offset (probe thickness in this case)
G0 z10 //move z up
M00 // end of break
G0 z5
M03
there are a lot of combinations possible to get same result , but hopefully i have the chance to ask an experienced
CNC Programmer next week, i want to get as much information as possible for a safe operation.
Also there are quite huge differences in availability of G or M- codes depemding on the software you use.
(for example Mach3 , Linux CNC , CamBam etc.)
From my point of view everyone using software to generate the code should be able to read and understand the code in file.
simulators are also useful.
manual movement is also a "nice to have" especially for finding workpiece offsets.
i did that via analog joystick on analog inputs , refer my post manual positioning / Jogwheel dated March 6
( works good but it´s improvable for shure , will see during working with that).
Let me see what CNC Programmer says next week , for the next days i´ll switch over to hardware design , Toys from China arrived today :-)
so we can read the coordinates also as a float value.
There are many G-Codes specified as fractional numbers.
just for example:
G29 G29.1 G29.2 G38 G38.1 G38.2 G41 G41.1 G43 G43.1 G43.2G92 G92.1 G92.2
I don´t actually know if there is a need for that stuff but may be it should be possible to implement that in future.
one other question regarding Z-Probe :
when i run G29 S2 Z-Probe it does everything ok , also new value is stored in Eeprom.
when i run G28 after that , Z height still shows old value in Display , changes to new one after Hardware reset only.
Why?
if(ok) {
sum *= 0.33333333333333;
Com::printFLN(Com::tZProbeAverage, sum);
if(com->hasS() && com->S) {
#if MAX_HARDWARE_ENDSTOP_Z
#if DRIVE_SYSTEM == DELTA
Printer::updateCurrentPosition();
Printer::zLength += sum - Printer::currentPosition[Z_AXIS];
Printer::updateDerivedParameter();
Printer::homeAxis(true,true,true);
#else
Printer::currentPositionSteps[Z_AXIS] = sum * Printer::axisStepsPerMM[Z_AXIS];
float zup = Printer::runZMaxProbe();
if(zup == ILLEGAL_Z_PROBE) {
ok = false;
} else
Printer::zLength = zup + sum - ENDSTOP_Z_BACK_ON_HOME;
#endif // DELTA
Com::printInfoFLN(Com::tZProbeZReset);
Com::printFLN(Com::tZProbePrinterHeight,Printer::zLength);
#else
Com::printFLN(PSTR("Adjusted z origin"));
#endif // max z endstop
Printer::feedrate = oldFeedrate;
Printer::setAutolevelActive(oldAutolevel);
if(ok && com->hasS() && com->S == 2)
EEPROM::storeDataIntoEEPROM();
for the fractional codes.
So for example the reprap G29 S2 is G29.2 in CNC.
As there are not too many Codes with fraction i think it can be solved by postprocessor in cam Software.
Even Cam softwares seem to have a kind of "dialect" for me i can figure that out.
May be i can take a look at DIN66025 in my office , i hope i get get access authorization.
Even the DIN is just our german standard it might give me some more information.think i opened a big barrel
for my "universal " solution so it´s time to make compromise ;-)
regarding the z-probe:
Homing dir ZMAX
for example i set Zmax to 200.0 ican see 200.000 in Eeprom(via Repetier Host) then i run G92 S2
if i go to EEprom again i can see 200.120 so Z-probe is updated and set to the new value.
If i now run g28 z on host shows 200.12 and LCD shows 200.00
after hardware reset and G28 both show 200.12
can that happen if i have set max_software_endstop_z true?
cannot check it at the moment, long print running , I´ll check it tomorrow
which cam software do you use?
