Custom Buttons with UI_KEYS_BUTTON_HIGH/LOW
                    Good Morning,
my name is Stefan and i experience a little problem. I have tried to add
some keys to my printer which i will use for milling. I have an RAMPS
1.4 with an MEGA.
The producer is Sainsmart. I have that Display: LCD
12864. That is the Kit:
http://www.sainsmart.com/arduino/arduino-kits/3d-printkits/ramps-1-4-a4988-mega2560-r3-endstop-lcd-12864-kit-for-reprap-3d-printer.html
In
the configurator i have choos that Display: RepRapDiscount Full Graphic
Smart Controller 128x64, RAMPS, RUMBA, Megatronics 2 & RAMBO
I have add that code in the uiconfig.h:
#define UI_HAS_KEYS 1
void uiInitKeys() {
#if UI_HAS_KEYS!=0
// Keypad, connect 5V to Pin x Pin 11, 57, 58 are empty
UI_KEYS_INIT_BUTTON_HIGH(0); // Zero all
UI_KEYS_INIT_BUTTON_HIGH(1); // Zero Z
UI_KEYS_INIT_BUTTON_HIGH(4); // slow X
UI_KEYS_INIT_BUTTON_HIGH(5); // slow Y
UI_KEYS_INIT_BUTTON_HIGH(6); // Babysteps Z
UI_KEYS_INIT_BUTTON_HIGH(63); // Left
UI_KEYS_INIT_BUTTON_HIGH(59); // Right
UI_KEYS_INIT_BUTTON_HIGH(40); // forward
UI_KEYS_INIT_BUTTON_HIGH(64); // backward
UI_KEYS_INIT_BUTTON_HIGH(42); // up
UI_KEYS_INIT_BUTTON_HIGH(44); // down
UI_KEYS_INIT_BUTTON_HIGH(65); // Home all
UI_KEYS_INIT_BUTTON_HIGH(66); // Emergency stop / Or disconnect current??
#endif
void uiCheckSlowKeys(uint16_t &action) {
// ----- End RGB shield ----------
#endif
//UI_KEYS_MATRIX(32,47,45,43,41,39,37,35);
// Keypad, puch button, connects 5V to pin
UI_KEYS_BUTTON_HIGH(0,UI_ACTION_SET_ORIGIN); // Zero all
UI_KEYS_BUTTON_HIGH(1,UI_ACTION_SET_Z_ORIGIN_BUTTON); // Zero Z defined in ui.ccp and ui.h
UI_KEYS_BUTTON_HIGH(4,UI_ACTION_XPOSITION); // slow
UI_KEYS_BUTTON_HIGH(5,UI_ACTION_YPOSITION); // slow
UI_KEYS_BUTTON_HIGH(6,UI_ACTION_Z_BABYSTEPS); // slow
UI_KEYS_BUTTON_HIGH(63,UI_ACTION_Y_UP); // Left
UI_KEYS_BUTTON_HIGH(59,UI_ACTION_Y_DOWN); // Right
UI_KEYS_BUTTON_HIGH(40,UI_ACTION_X_UP); // forward
UI_KEYS_BUTTON_HIGH(64,UI_ACTION_X_DOWN); // backward
UI_KEYS_BUTTON_HIGH(42,UI_ACTION_Z_UP); // up
UI_KEYS_BUTTON_HIGH(44,UI_ACTION_Z_DOWN); // down
UI_KEYS_BUTTON_HIGH(65,UI_ACTION_HOME_ALL); // Home all
// UI_KEYS_BUTTON_HIGH(66,UI_ACTION_EMERGENCY_STOP); // Emergency stop / Or disconnect current??
#endif
#endif
The problem i get is:
The Buttons doing absolutely nothing oO
Can anyone tell me what is going wrong?
Another short question:
In that part:
case UI_ACTION_SET_Z_ORIGIN_BUTTON:
GCode::executeFString(PSTR("G92 Z0"));
break;
is it also possible to send a M command?
I hope for a fast response and sorry for my bad english.
Kind regards
Stefan
1.4 with an MEGA.
In
void uiInitKeys() {
#if UI_HAS_KEYS!=0
#endif
#endif
#endif
#endif
In that part:
break;
Kind regards
Stefan
1. what type of Switches do you use ? n.c. or n.o?
2. M command is possible the same way
greetings from munich ;-)
Yes Munich, correctly
I use n.o switches. They connect 5V while i am pushing the Button (Taster).
Kind regards
Stefan
does your Rotary Encoder work?
how is Display connected? Looks like double use of Pins...
I´m not familiar with the config tool , while I´m doing Settings Manual .
maybe you can take a look at configuration.h at line around1600 which Controller is set
sorry i have only 988 lines
I've found that two lines (perhaps you need to tell me the option):
#define FEATURE_CONTROLLER 11
"uiController": 0,
The Display has an Rotary Encoder and 3 Switches (Encoder, Stop/Reset, Light for Display)
Here is everything working fine and i did not get any problems.
I have take a look on the RAMPS 1.4 shematic. That are the Digital Pins of Servos, Aux1 and Aux2:
http://reprap.org/mediawiki/images/thumb/c/ca/Arduinomega1-4connectors.png/800px-Arduinomega1-4connectors.png
I didn't think that i have a double use.
is there something written about uikeys in your config.h?
like:
#define FEATURE_UI_KEYS 0
if yes, set it to one
yes i get it:
is that the error?
where did you add the code ? in uiconfig.h or in ui.h?
uiconfig only works if you set Feature_Controller 1.
so you have to set Pins for Display also in uiconfig. h
Settings for Controller 11 are located in ui.h , also the init and check the keys.
i suggest you should define the keys and Display manually in uiconfig in order of not changing
the Standard Settings.
so check ui.h from line 645 to 677 for display
and for your ramps line 834 to 854 for pin Settings
move that Settings to uiconfig.h , so that should work
sorry ich verstehs nicht..
so i have take a look in the ui.h.
(Only for testing)
I have set from line 642 (void uiInitKeys() ) my key init:
void uiInitKeys() {
// UI_KEYS_INIT_BUTTON_HIGH(66); // Emergency stop / Or disconnect current??
And i have set in line 660:
I have a RAMPS so i have take a look to line 867:
Here is defined:
#else // RAMPS
#undef BEEPER_PIN
#define BEEPER_PIN 37
#define UI_DISPLAY_RS_PIN 16
#define UI_DISPLAY_RW_PIN -1
#define UI_DISPLAY_ENABLE_PIN 17
#define UI_DISPLAY_D0_PIN 23
#define UI_DISPLAY_D1_PIN 25
#define UI_DISPLAY_D2_PIN 27
#define UI_DISPLAY_D3_PIN 29
#define UI_DISPLAY_D4_PIN 23
#define UI_DISPLAY_D5_PIN 25
#define UI_DISPLAY_D6_PIN 27
#define UI_DISPLAY_D7_PIN 29
#define UI_ENCODER_A 33
#define UI_ENCODER_B 31
#define UI_ENCODER_CLICK 35
#define UI_RESET_PIN 41
#endif
Here i have add
#define UI_ACTION_HOME_ALL 65
but i didn't do anything.
Can you explain your steps?
i get it. I defined that one in the ui.h:
#else // RAMPS
#ifdef UI_MAIN
void uiInitKeys() {
UI_KEYS_INIT_CLICKENCODER_LOW(UI_ENCODER_A, UI_ENCODER_B); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
UI_KEYS_INIT_BUTTON_LOW(UI_ENCODER_CLICK); // pushbutton, connects gnd to pin
UI_KEYS_INIT_BUTTON_LOW(0); // Zero all
UI_KEYS_INIT_BUTTON_LOW(1); // Zero Z
UI_KEYS_INIT_BUTTON_LOW(4); // slow X
UI_KEYS_INIT_BUTTON_LOW(5); // slow Y
UI_KEYS_INIT_BUTTON_LOW(6); // Babysteps Z
UI_KEYS_INIT_BUTTON_LOW(63); // Left
UI_KEYS_INIT_BUTTON_LOW(59); // Right
UI_KEYS_INIT_BUTTON_LOW(40); // forward
UI_KEYS_INIT_BUTTON_LOW(64); // backward
UI_KEYS_INIT_BUTTON_LOW(42); // up
UI_KEYS_INIT_BUTTON_LOW(44); // down
UI_KEYS_INIT_BUTTON_LOW(65); // Home all
// UI_KEYS_INIT_BUTTON_LOW(66); // Emergency stop / Or disconnect current??
#if UI_RESET_PIN > -1
UI_KEYS_INIT_BUTTON_LOW(UI_RESET_PIN); // Kill pin
#endif
void uiCheckKeys(uint16_t &action) {
#if FEATURE_CONTROLLER == CONTROLLER_BAM_DICE_DUE
UI_KEYS_CLICKENCODER_LOW_REV(UI_ENCODER_B, UI_ENCODER_A); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
#else
UI_KEYS_CLICKENCODER_LOW_REV(UI_ENCODER_A, UI_ENCODER_B); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
#endif
UI_KEYS_BUTTON_LOW(UI_ENCODER_CLICK, UI_ACTION_OK); // push button, connects gnd to pin
UI_KEYS_BUTTON_LOW(0,UI_ACTION_SET_ORIGIN); // Zero all
UI_KEYS_BUTTON_LOW(1,UI_ACTION_SET_Z_ORIGIN_BUTTON); // Zero Z
UI_KEYS_BUTTON_LOW(4,UI_ACTION_XPOSITION); // slow
UI_KEYS_BUTTON_LOW(5,UI_ACTION_YPOSITION); // slow
UI_KEYS_BUTTON_LOW(6,UI_ACTION_Z_BABYSTEPS); // slow
UI_KEYS_BUTTON_LOW(63,UI_ACTION_Y_UP); // Left
UI_KEYS_BUTTON_LOW(59,UI_ACTION_Y_DOWN); // Right
UI_KEYS_BUTTON_LOW(40,UI_ACTION_X_UP); // forward
UI_KEYS_BUTTON_LOW(64,UI_ACTION_X_DOWN); // backward
UI_KEYS_BUTTON_LOW(42,UI_ACTION_Z_UP); // up
UI_KEYS_BUTTON_LOW(44,UI_ACTION_Z_DOWN); // down
UI_KEYS_BUTTON_LOW(65,UI_ACTION_HOME_ALL); // Home all
// UI_KEYS_BUTTON_LOW(66,UI_ACTION_EMERGENCY_STOP); // Emergency stop / Or disconnect current??
Should i copy that in the uiconfig.h? If yes what i should copy?
Another question:
At the moment it drive 1mm and stops. Then it drives 1mm and stops (so lang as i press the button) is there
a possibility to "smooth" that?
With which Action i will only drive 0.1 mm or less? (Can i set a command or G code to switch in a "slow" mode)
for moving smaller steps you have to write a ui_action.
handling can be done like this :
case UI_ACTION_Y_UP01:
if(!allowMoves) return action;
GCode::executeFString(PSTR("G91\n G1 Y 0.1 F200 \n G90\n"));
break;
or another way:
(thats the way original move is done)
case UI_ACTION_Y_DOWN01:
PrintLine::moveRelativeDistanceInStepsReal(0, ((action == UI_ACTION_Y_UP01) ? 1.0 : -1.0) * Printer::axisStepsPerMM[Y_AXIS]/10, 0, 0, JOGRATE, false,false);
break;
it´s just typing;-)
so have i take that lines in the uiconfig.h:
// Special pins for some u8g driven display
// Defined for RAMPS from ui.h
#undef BEEPER_PIN
#define UI_DELAYPERCHAR 50
#define UI_ENCODER_SPEED 2
#endif
#ifndef UI_INVERT_MENU_DIRECTION
#define UI_INVERT_MENU_DIRECTION 0
#endif
/** \brief Are some keys connected?
0 = No keys attached - disables also menu
1 = Some keys attached
Was that right? I didn't commend anything out. I didn't get an error while i'm compiling
A great Tip for all others: Don't use the keys with HIGH, Use the Keys with LOW and connect them to ground.....
I think i would use that version becouse i understand it:
break;
Is there a possibility to set an Switch with that function:
I set the Switch to LOW and while it is LOW all axes will drive with 0.01 mm?
Another point is that:
I have created that keys:
UI_KEYS_BUTTON_LOW(59,UI_ACTION_Y_UP); // Left
UI_KEYS_BUTTON_LOW(63,UI_ACTION_Y_DOWN); // Right
UI_KEYS_BUTTON_LOW(44,UI_ACTION_Z_UP); // up
UI_KEYS_BUTTON_LOW(42,UI_ACTION_Z_DOWN); // down
When i drive with the keys the printer will do 1mm, stop, 1mm, stop, 1mm, stop, and so on.
Is there a possiblity to smooth that, that the printer will drive the way without stops ever 1mm?
A lost question to your last post:
Wy you are useng that command?:
Becouse that will work too:
GCode::executeFString(PSTR("G1 Y 0.1"));
is that the point to make it more smooth?
Greetings
Stefan
Hi Stefan,
please send me your uiconfig.h by e-Mail i´ll check it for you.
NO it´s not the same
G91: sets move to relative positioning
G1 Y 0.1 F200 moves x by 0.1mm to + direction
G90 goes back to absolute positioning
for example : machine is at Position x=10mm it will move to Position10.1mm
if you don´t use the G91/G90
for example : machine is at Position x=10mm it will move to Position 0.1mm
that´s the difference
F says just the Speed(F for feedrate) and 200 means 200 mm/min what is quite slow
Greetings
Robert
