Board fan PWM
                    Hi Repetier,
It would be nice to be able to set the board fan PWM via a #define. It is already being PWMed but with a hard coded value of 255 for the speed.
Thank you,
Errol
Thank you,
Errol
Can You add to fw min. speed of board fan (with able to set via PWM) when printer is in stand by mode (not priting)?
I have board and power supply in case and currently board fan is on only if headbed or stepper motors is active. Otherwise not, but my power supply is not cooled with board fan. Thank You.
PS: sorry for my english
When i finding string "BOARD_FAN_MIN_SPEED" in fw, it is only in configuration.h file
Now it works, but only after print. I require that work also before print.
We are on good way
Thank You very much.
Thank You for Your patience ;-)
