Z probing documentation
Hi I am following the documentation on ttps://www.repetier.com/documentation/repetier-firmware/z-probing/
I am wondering if there is an error in the documentation. In the firmware you note Z_PROBE_HEIGHT is the difference between activated probe position and nozzle height.
In the documentation you note it as "Z_PROBE_HEIGHT is the height difference between z-probe trigger and bed."
Which one is correct ?
