fan control
just built a large delta tested it with marlin everything seams ok --- trying repetier.
how do I achieve this :: in repetier.
#define CONTROLLERFAN_PIN 8 //Pin used for the fan to cool controller, comment out to disable this function#define CONTROLLERFAN_SEC 60 //How many seconds, after all motors were disabled, the fan should run//This is for controlling a fan that will keep the extruder cool.#define EXTRUDERFAN_PIN 6 //Pin used to control the fan, comment out to disable this function#define EXTRUDERFAN_DEC 80 //Hotend temperature from where the fan will<br>plastic cooling on Pin 7 I am using a Rumba board.any help will be appreciatedmalc
thanks works a treat.
now have extruder fan with led when heats over 50 and also shuts off below 50.
board-cooler-fan when any stepper movment.
plastic cooler-fan controlled by repetier ---- great
malc
