MJPG-streamer in "0.80" SD version for Raspberry
I need to change the default cam resolution on MJPG-streamer.
This doc is not usefull with the new "SD image" of version 0.80 for Raspberry, the default path is different.
https://www.repetier-server.com/setting-webcam-repetier-server-linux/
Where is it the right file with inside the MJPG-streamer settings?
sudo nano /etc/init.d/mjpgstreamer<br><br>This file doesn't exist in the "SD" version...<br>/usr/local/Repetier-Setup/templates/mjpeg_streamer.service.usb
When you think to release the next SD version?
But if i put inside this file some wrong parameters and then restart the webcam streamer the cam it doesn't work! :-)
"In server->configuration select activate usb to install your modified version."
Anyway please in the new version considers to be able to upgrade the current system "0.80 SD", it's a bit boring having to formatting the SD and riconfigure all.
I know that the printer settings can be exported, but is not the only customizations that maybe one did (vnc server and other add-on and settings).
